35x12.50's without a lift?
Has anyone run 35x12.50 tires on a 2002 2500 without a lift? I currently am running 305/70r16 which I believe to be roughly a 33 inch tire. They fit fine, with only a small amount of rubbing at full lock.
I found a good deal on these 35's mounted on 18" wheels, that I would love to get, so I can do the third gen brake upgrade. But the tires/wheels are not in a situation that I can try one on first.
I did try a 37x15.50 tire and it hit the fender before I turned the wheel 1/4 turn. Those would probably need a 6" lift at least to clear.
I would put a leveling kit in the front if I needed to, and in the rear my truck has the extra heavy spring pack already so it sits higher than a standard 2500 to begin with.
From: Stony Plain, Alberta, Canada (just outside Edmonton)
I'm pretty sure you will need a leveling kit (2"). My buddy had an '01 and put the leveling kit on, and was running 35X12.5's with a small rub on the control arms. I am currently running 33X13.5's with the leveling kit and have some small rub on the control arms.
JaimeG
Mar 26, 2009 06:58 AM
06Cummins
Oct 25, 2006 10:23 PM
anestech*
May 26, 2004 08:52 AM
Sarge1124
Dec 30, 2003 02:59 PM
