2500 to dually conversion
Arrowcraft does make good kits.....don't have a clue as to the complete kit cost. I know I certainly wouldn't bother doing a conversion. I looked into this myself when I had my 2500 - it just wasn't worth it. I could have an OEM dually (much better, IMO...unless you find a dually box) for significantly less cost by simply selling the 2500 and buying a 3500. So, guess what I ended up doing?
I'm looking into the project as well. Only I will be ditching the bed and adding a flatbed to the truck. So this is much more cost effective to me. As far as the beds go, I would look at local machine shops that sell & install flatbeds. Usually they offer to buy the pickup beds they remove from the trucks and they either sell them to the public or to body shops. The body shops around here always have 2 or 3 dually beds out front. As far as the parts for the conversion, I will get all the spacers and 1 ton springs and overloads from the dealership.
Just replacing the rear axle, adding dual wheels (and two more $185 tires) and a new bed to your truck, does not a dually make.
Now for a flatbed, this conversion would make sense, and you could have the option of leaving single rear wheels if your loads won't be overally heavy.
May I ask - why would you really want to do this anyway? I know they look nice, but have you actually driven a dually on snow? Since you don't list where you reside statewise, this may be a genuine concern you should consider. It's a whole different animal in the snow than a SRW would be...
) then I'll probably look at running studded tires in the winter. As far as why not just buying a dually, because my truck is set up the way that I want, and I know the history of my truck. I know that I've taken care of it, it hasn't been idled for long periods of time, or had hot shut downs, or been overheated with excessive egrs. It's more a matter of comfort than anything else.
I live in NY Long Island. I am not concerned about snow.Like JAX said I just want the stability of DRW but I dont need the GVW I just tow a 20' enclosed trailer with a mustang in it ( not the horse) and I like MY truck.
I emailed Arrowcraft for some info,Ill see what they say.
well I am in the process of converting to a single wheel.. If you need any of the spacers or such just let me know. I have the factory fron hub extentions and wheels for you so If you are interested let me know!!
the arrowcraft kits make the rear end WAY too wide!!, my cousin tried this on a 99' 2500, & it looked horrible, he ended up swapping in a cab & chassis rear axle & it had a factory look then, the rear springs should be the same if you already have overloads & all you need in the front are the adapters & there are usually a few sets on ebay reasonable, if you're goin with a flatbed I'd try & find a C&C axle for the rear, if not you may be satisfied with the Arrowcraft spacers, but I was told that the outside tires on the rear would stick out past the factory fenders a couple inches, the lady at Arrowcraft said that I could put, "some of those little rubber fender flares on it & that's all I would need"!! LOL I decided to swap trucks rather than go through the hassle, good luck whatever you decide, Dusty
well i finished mine yesterday and i love it ...
i had a cab and chassis dana 80 for a year now ...
had 35's and 3rd gen rims ... sold them for the same price as six third gen rims, tires, hubcaps and lug nuts
bought the front spacers for 100$ a piece ...
bought warn flares for 200$ ... because the c/c was 1" more narrow per side than a srw the flares cover all but about 1/2" of rubber ... looks sharp and no more ping ping on the gravel road i live on ... hopefully johnny law will leave me alone
this is great
couple more leaves will go underneath this weekend
hmmm ... drivetrains the same ... frames the same i guess two more tires does a dually make ... bad in the snow ... wow we get snow a lot around here and i have'nt a rash of duallys in the ditch
this is great
i have a 96 dually and a 94 single could i just pull the rearend from the dually and put it on my single and put the single where the dually was? u bolts are the only thing holding it on right? do you guys know if i can do this?thanks
