1997 3500 Rear Brake Lights stay on.
Old Jan 10, 2021 | 11:56 AM
Rooman789's Avatar
1997 Ram 3500 Rear Brake Lights stay on.
I have been trying to diagnose this for about a month now and now I’m reaching out for help. To give an overall synopsis.
1. I have removed the brake switch and replaced. I have manually tried to press the button and the lights remains on.
2. I unplugged the combination blinker switch and the lights go out but third light remains on. I replaced the combo switch and still have the same problem.
The only way to turn them off is to pull the main fuse under the hood which is done just to save batteries.
Any help is greatly appreciated.
Last edited by Rooman789; Jan 10, 2021 at 11:57 AM. Reason: Add vehicle description
Old Jan 10, 2021 | 04:02 PM
AlpineRAM's Avatar
Does your truck have cruise and does it work?
IMO you can have a brake switch that stays on (or you try to lift the brake pedal and see if the light goes out- pedal return spring) or a short in the wiring that makes the brake light stay on.
Old Jan 16, 2021 | 09:36 AM
Rooman789's Avatar
It has a cruise but unsure if it works due to drivetrain in shop.
Old Jan 16, 2021 | 10:34 AM
AlpineRAM's Avatar
If you unplug the brake switch (without removing it from it's bracket) does the light stay on?
Old Jan 16, 2021 | 10:40 AM
Rooman789's Avatar
Yes it stays on.
Old Jan 16, 2021 | 02:21 PM
AlpineRAM's Avatar
OK, it is a wiring problem then.
You say it lights up as soon as you connect the battery? (And have the fuses installed)
It seems that you get a permanent hot to the brake light hot somewhere-
I'd try to start pulling the fuses in the cab one by one and note if/when it goes out.
This could help to identify the source circuit.
Did you do anything to the truck before this started or did it just come up with it out of the blue?
Old Jan 17, 2021 | 09:40 AM
AlpineRAM's Avatar
Another possible solution:
rockyota83
Dec 5, 2024 11:03 AM
pjc360
Jan 11, 2018 01:15 PM
TrkEnvy
Jul 2, 2012 11:02 PM
Nathan
Feb 15, 2011 09:05 PM
heimancowboy
Dec 5, 2008 06:19 PM
