1994 Ram brake controller harness: Help
Old Nov 11, 2010 | 04:50 AM
Sandpiper TD's Avatar
Hello, I'm a new guy. I have a 1994 ram 2500 that came with the factory tow package (7 way trailer plug prewired). I am trying to locate the brake control factory harness plug under the dash and couldn't find it to save my life. I have searched all of the threads and it sounds like it should be there (either white or blue connector)My truck even came with the brake control pigtail along with a heavy duty flasher and relay that is new in the box and was in the glove compartment (the previous owner never towed anything). Is it possible that there isn't a harness under/behind the dash even though it came with everything from the factory (ie relay, flasher, 7 way connector, brake contro pigtail)? I looked long and hard and there is no 4 pin connector....There is only a light blue wire that says "trailer B+ max 15 amps". I even took off the plastic cover under the steering wheel to get a better look. There is not a plug anywhere. Can I wire the plug from the PDC under the hood somehow? I located the wires from the rear 7 way plug that come up along the drivers front fender but after that I can't find anything else. PLEASE HELP
Old Nov 11, 2010 | 09:53 AM
Busboy's Avatar
Mine was taped up to other wires just to the right of the steering column and was difficult to find. It was not very long maybe 8 inches. I would look again, it must be there if the truck was prewired with a towing package.
TrueBlueInBak
Oct 18, 2007 08:41 PM
j
Jul 25, 2007 12:47 PM
MR HYDROSEED
0
Mar 27, 2005 06:54 PM
linetrash75
Oct 10, 2004 06:05 PM
erics76
Dec 27, 2002 05:19 PM
