2nd Gen All Products Sell all of your 2nd gen products here. This includes trucks, parts, accessories etc.
Engine & Drivetrain Huge lot of brand new Cummins 12v parts
Old Today | 11:03 AM
WickedQuick12v's Avatar
2nd gen dodge 12v Cummins 94-98 parts
Located in New England
Sold my truck and the buyer didn't want the parts
Everything is in great shape and been stored properly for the past year. Some parts are extras or leftovers from my build. Some were for future projects.
Willing to let it all go for CHEAP. No one up here in the northeast drives 2nd gens anymore. Not having luck selling local..
Tie rod adjuster sleeve for HD steering (Moog)
94-98 to 98.5 HD steering stabilizer/bracket (new)
Front hub to knuckle sheet metal spacer (used good)
Sway bar bushings (new)
Spicer ball joints upper/lower (Dana 60)
Spicer ball joint knuckle inserts (new)
Spicer u joints 5-1330-1x (new) x2
Spicer u joint 5-1309x new) x1
3rd gen track bar w/ new energy suspension bushings (used good)
2nd gen to 3rd gen track bar conversion kit (94-02)
CAD shifter arm bushings spicer x2 (new)
CAD axle bushing spicer (new)
CAD housing (used)
CAD gasket (new)
Lube locker diff gasket Dana 60 (new)
Assorted u joint snap rings (new)
DELPHI lift pump (new)
Internal oil cooler rebuild kit ( new OEM Cummins)
Crank dampener pulley ( new OEM Cummins)
Gates green fleet serpentine belt (new)
Serpentine belt (used good)
Killer dowel pin kit w/ extra crank seals (new)
High performance intercooler boots (new)
air cooler band clamps (used and new)
Injector nuts (used)
Complete engine gasket kit (victor reinz)
Oil pan gasket (mahle)
Valve cover gaskets (mahle)
Valve cover bolt seals (OEM new)
Assorted extra head gaskets/seals (new)
Random assortment of Injector/fuel system seals
Gould gear vac pump reseal kit w/ DVD instructions
Vac pump to timing case seal (used good)
Vac pump to timing case seal (new)
Vac pump o ring seal (OEM new)
Timing case oil fill seal (new)
Intake horn gaskets (OEM new)
Power driven diesel pushrod cover gasket (new)
12 valve valve stem top hat seals PDD (new)
24 valve tappet washers and crossover tubes (new)
1st gen 12 valve assorted seals (new)
Oil pan drain plug washer seals (OEM new)
12 valve valve seal kit (new)
12 valve tappet cover grommets PDD (new)
12 valve oil pan drain plug (used good)
Wix and Baldwin oil filters (new)
Turbo oil supply (OEM used)
Vibrant performance braided turbo drain kit (new)
High temp turbo drain hose (new)
Throttle cable (Mopar OEM new)
Throttle cable studs/bushings (new)
Throttle pedal bushings (new)
P pump timing plug w/ seal kit (OEM new)
P pump manual shutoff cable/brackets (new)
Injection pump oil feed tee (OEM new)
Injection pump oil line to block fitting (OEM new)
Injection pump nut and washer (OEM new)
47rh neutral safety switch (new)
47rh shift cable wire clip for end of cable (new) x2
47rh dipstick tube seal (new)
47rh transmission cooler rubber lines (new)
47rh cork pan gasket (new)
24 valve thermostat? (OEM Cummins new)
Brake pedal switch (new)
Abs sensor (new)
Lug nuts (used)
Front brake caliper bleeder valves x2 (new)
E brake line pedal to split (extra cab long bed)
Door panel clips (new)
Turbo pressure test cap
Fleece crank pulley barring tool w/ arp hardware(new)
Front crank seal drive tool (new)
Rear of motor barring tool (new)
Sockets for injection pump nut, injectors, axle nuts, wheel hub bolts and steering
high bid
0
May 20, 2026 06:42 AM
seakid
1st Gen All Products
Nov 18, 2019 10:22 PM
irocpractice
Jan 11, 2013 06:25 PM
