wrong tranny oil in 99
My truck leaks transmission oil & on my way to work yesterday while fueling up I checked my transmission oil & it was 2 quarts low...they didnt have any of the proper oil (what is it called anyway... mopar 4?) so in a panic I put in 2 quarts of pennzoil atf....now im imagining my transmission slowly dieing...should I be in a big panic & change all the oil? Is this a big job? Where is a common place where they leak? Everything is oily under there!
thanks Doug |
No, it won't kill the tranny, especially with so little of the other stuff in there. If you were to change all of it for another type it might perform differently, but I doubt you can notice any difference with your current ratio. I used to put Type F in GM transmissions to get them to shift harder. This is because Type F had a higher viscosity than ATF. I have even heard of experimentation with using hydraulic fluid in them.
Put the right stuff in at your next scheduled change and you'll be fine. Chris |
Originally Posted by Stamey
(Post 2782186)
