Will this work?
Will this work?
Could I just use a gauge like this:
http://cgi.ebay.com/ebaymotors/ws/eB...477063888&rd=1
to put on top of my fuel filter on my 98' 24-valve to check fuel pressure while under the hood. I don't have enough money right now to buy gauges for in the cab, but thought it would be convenient to be able to check it while under the hood.
Thanks.
Thanks.
That'll work, but you should prolly have a 0-30 psi guage.....
I personally think you would be better off saving your money and using it to get the correct guage to mount in the cab. The pressure reading at idle isnt very representative of lift pump health and means next to nothing. You want to measure at W.O.T.. I say save your money and get a good mechanical ISSPRO FP guage with some braided hose or similar. That way you dont have to screw around with senders and isolators, IMO.
OR get yourself a Brair Hopper temporary FP guage that u can tape to the windsheild. www.blackmountaindiesel.com
Good Luck with it.
Good Luck with it.
Thanks for the info. What about this westach gauge from geno's. I would be able to get this:
http://216.167.41.9/CoastalData/show...ID=891&CATID=1
Let me know if westach is any good, if not I guess I'll have to start saving up for the ISSPRO. I don't have time tonight, but tomorrow I will research this. Any feedback would be great.
I've had the Westach 0-30 FP gauge for just over two years now, and it's worked flawlessly. I originally had the 0-15, and had to order the 0-30 because the 0-15 kept getting stuck at the top of the gauge when at idle.
Re: fuel pressure hook up
Originally posted by jigdog
if i am going to check my fuel press under the hood can i just hook it to the vp schrader to check it or do i need to go elsewhere?
If you take it in complaining of low power, that's where the Dodge tech will test it as well.
phox
I do not recommend the mechanicals in the cab. I have installed & taken out the second ISSPRO in less than a month. I am using steel braid line. The guages keep leaking all over my dash. I am going to try a WESTACH when I get around to ordering one. I have gotten MIXED results from everyone that has tried them. The ISSPROS keep leaking around the little rivets at the top of the guage on the back. Has anyone else experienced this problem? I like burning diesel, but I don't like in my cab.
I put a similar little (1.5") autometer on top of my fuel filter housing and it has served me well. I usually take a quick peak about once a week to make sure I still have pressure. The lift pump that went south on me did so gradually, working it's way down to about 8-9psi at idle. I just keep an I on it, and get my wife to stab the throttle so I can see what it does while my head is under the hood.
