Where is my oil pressure sender?
Old Jun 12, 2006 | 09:57 PM
one54ton's Avatar
Is it under my VP44 or along the block?
Old Jun 13, 2006 | 06:13 AM
Shovelhead's Avatar
Administrator / Scooter Bum
number 22 is the Oil Pressure sender
the other components:
Fuel System Components - 24-valve Cummins Turbo Diesel engine.
1. Fuel Transfer (Lift) Pump
2. Fuel Return Line (to Fuel Tank)
3. Fuel Supply Line (Low Pressure, to Engine)
4. Fuel Heater
5. Water-in-Fuel (WIF) Sensor
6. Fuel FilterlWater Separator
7. IA T Sensor
8. Map (Boost) Sensor
9. Fuel Drain Manifold
10. CKP Sensor
11. CMP Sensor
12. Overflow Valve
13. Drain Valve
14. Fuel Pressure Test Potts
15. ECM
16. ECT Sensor
17. Fuel Injection Pump
18. Throttle Lever Bell Crank and Apps
19, High-Pressure Fuel Lines
20. Fuel Injectors
21. Fuel Heater Temperature Sensor (Thermostat)
22. Oil Pressure Sensor
23. Fuel Injector Connector
24. Drain Tube
25. Intake Manifold Air Heater/Elements
Credit to www.dodgeram.org
Old Jun 13, 2006 | 08:18 AM
one54ton's Avatar
your the man. thanks
Royal
17
Jan 24, 2006 04:43 PM
wcbcruzer
May 18, 2005 03:26 PM
turboram
Feb 18, 2005 10:33 AM
