VP44 trouble - How to get codes?
Old Aug 6, 2004 | 01:40 AM
Ram44maR's Avatar
Question VP44 trouble - How to get codes?
Hello out there,
I've been searching/reading multiple posts over the past few days and have come to the conclusion that I probably have a defective VP44 [65,000 miles--probably comes as no surprise].
Unfortunately, I'm out of warranty and driving the truck at this point is a very risky proposition. I have no diagnostic equipment or code readers, so I'm wondering about using the instruments to access trouble codes?
I've also read some posts regarding using the digital odometer to get codes, but the suggestions and steps vary widely.
Here's what I've tried:
I hold the odometer reset while I turn the key to the ON position.
Here's what I see on the odometer:
1) "CHEC" indication
2) "TRIP888888" indication
3) A readout segment test that looks like a rolling segment
4) The actual mileage + ALL warning indicators
5) ALL gauges simultaneously move to 1/4 scale, 1/2 scale and then full scale
6) Back to normal operation
Question: Am I merely running an instrument panel self test routine OR is this how you access any set trouble codes?
If this is how you access any set codes, I assume I've got no trouble codes stored?
After I'm up and running again, I'd like to get a good diagnostic tool [possible employing the OBDII interface]. HOW MANY OF YOU OUT THERE HAVE HAD GOOD LUCK USING AN OBDII SCANNER or some other type of code scanner with a '98.5 CTD? If you have, PLEASE let me know who supplies them. Also, I'd really appreciate any links anyone can supply. I know this is a lot, but I'm pretty much dead in the water right now.
Thanks so much,
Bill
Old Aug 6, 2004 | 06:24 AM
243's Avatar
243
On my 01, I turn the key off-key on (without starting) three times. On the third key on, the odometer window flashes the codes and finishes with P DONE. So far no codes...good luck.
Old Aug 6, 2004 | 06:33 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The early early 24 valvers ('98-'99) trucks didn't have that feature.
The only way to "pull" codes is with a DTC reader.
Old Aug 6, 2004 | 06:39 AM
BigBlue's Avatar
Re: VP44 trouble - How to get codes?
Originally posted by Ram44maR
Question: Am I merely running an instrument panel self test routine...
Thanks so much,
Bill
Yup. Swing by an autozone and have them pull the codes for you.
ridlangus123
Dec 30, 2013 08:36 PM
danalex
Jul 3, 2010 09:01 AM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
