Vibration at Idle
Vibration at Idle
I have a vibration at idle that goes away when the rpm comes up. Thought it was a bad injector but I replaced them and it didn't fix my problem. Other than the vibration the truck seems to run strong, any suggestions to what this might be would be great. 2000 2500 4x4 Quad cab.
If you can get a hold of someone, or own a diagnostic program, turn off cylinders one by one and see if you can find the one that is misfiring. Maybe you have a leaky injector or a bad copper seal, or a particle under the seal that stayed there when injectors were changed?
dodgedsl03
Jan 18, 2007 10:08 PM
Jdub
14
Sep 25, 2003 04:44 PM
