U Joint Replacement
Old Jul 31, 2006 | 06:20 PM
Dr. Evil's Avatar
U Joint Replacement
Guys, I have a noise on drivers side - Im thinking U-joint. I havent crawled under the truck yet but do any of you have tips on diagnosing worn U Joints? or other front end components?
Thanks.
Old Jul 31, 2006 | 06:31 PM
hotdram's Avatar
Tips? Uh, start up front
The end that looks like this:
Driveshaft u-joints weren't too bad. Much cheaper at Napa than the dealer. Does the noise change with speed? Any "snap" in the driveline?
Have someone else spin the wheels while you listen closely to the u-joints.
Just keep this in mind if you do the drive shaft:
When I pulled out the slip yoke, I lost all the ATF-4 in the transfer case because I DID NOT have the rear end up higher than the front end.
After I looked at the u-joints coming out of transfer case to the front diff, I decided I did not want to mess with those. I would pay someone else. They looked like a pain to get to.
~Rob
Old Jul 31, 2006 | 07:01 PM
Dr. Evil's Avatar
~Rob
Thats what I was talking about. Will have a look at it in a bit.
Thx Rob !
Old Jul 31, 2006 | 08:03 PM
MedicShawn's Avatar
I just had some u-joint go bad on my 2004 with 40K. I just pulled the whole drive shaft fram the transfer case to the rear diff and had them replace all 3 u-joints and the hanger bearing for 222. The hanger bearing was damaged from all the driveshaft vibration. They said one of my U-joints was down to dust in the bearing cap.
Old Aug 1, 2006 | 05:28 PM
Joe Diesel's Avatar
i went in to the mechanic put it on the hoist rasied it off the ground dropped it in 4x4 & we found which U-joint was bad, which was the front right ... so just incase i replaced both sides
Old Aug 1, 2006 | 06:07 PM
Dr. Evil's Avatar
What kind of noise did it make? Kind of a vibration or growl (for lack of a better word) ??
Old Aug 2, 2006 | 07:35 AM
Joe Diesel's Avatar
it was a low growl, but when i did a donut at low speeds it was loud & clunky
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
zookeeper
Apr 5, 2004 05:33 PM
