turck hesitates from start
oops hit enter didnt finish thread
after removed edge ez and unplugged ecm and plugged back in.
truck has a lag example: form start if i stomp on it i get about a 1 second delay before truck actually comes to life.
same thing if coasting with foot off gas. once i re apply it has same delay. i tried resetting apps. didnt work. this is really annoying.
problem 2.
when starting from a dead stop when i hit the gas there is a clunk like a bad universal joint. same when coasting and re applying gas. any suggestions?
problem 2.
I've got nothing on the ECM stuff. However, in an unrelated work truck, danger ranger, we had (have) a bad clunk in gas-off gas-on situations. Its the transfer case in that situation. I know the Dodge cases are significantly stouter, but after checking your U-joints, you might look into that too.
On second thought, could the EZ have made enough of a difference to the truck feel that the lag you feel is simply the stock fueling and timing so it just "feels" really slow? I know every time I put my Smarty back to stock I wonder how I got along without it.
BRUISER
Dec 12, 2006 03:37 PM
dieselman24
Jan 16, 2005 06:20 AM
DynamicalyUnstable
Jun 20, 2004 02:55 PM
DynamicalyUnstable
Jun 20, 2004 02:05 PM
