Turbo Boot Problem
Old Feb 24, 2004 | 10:06 AM
j28s's Avatar
Question Turbo Boot Problem
I have a problem with one of the rubber hoses that exits the turbo and goes over metal hose (the rubber boot/hose clamps over the metal hose) that goes into the intercooler. Every time I pull a trailer, the rubber boot/hose blows off. The same one in the same place...blows off on the underside. Each time I put it back on, and tighten the heck out of the thing. Anyone else have this problem? Any idea why or what to do to fix it? Is there an aftermarket product on the market that's better? Thanks!!!
Old Feb 24, 2004 | 10:53 AM
Smokee's Avatar
Also, pull the boot, clean everything well with brake cleaner, spray the connection with hair spray, and boot it!
Old Feb 24, 2004 | 10:55 AM
MLR1's Avatar
Try cleaning the boot and pipe with alcohol then spray with hair spray and reassemble and it should hold.
Old Feb 24, 2004 | 11:48 AM
billg's Avatar
Take this link and go down about half way you will see a replacement set.
http://www.piersdiesel.com/DodgeProducts.htm
If it is giving you that much trouble I would replace it and be done with it.
Just my $0.02 worth.
Old Feb 24, 2004 | 12:34 PM
j28s's Avatar
Thanks for the information!!! I'll try what you guys mentioned below. Thanks again!!!
95black2615
Oct 8, 2008 03:34 PM
goodtyms
Jun 2, 2006 10:50 PM
09798794
Feb 16, 2006 02:30 PM
451Mopar
13
May 2, 2005 09:35 AM
