Truck surging
Old Mar 5, 2007 | 06:55 PM
Twodiesels's Avatar
Truck surging
Hello,
My truck all of a sudden started surging at steady throttle. It doesn't do it when accelerating, just when you are up to speed and cruising. I got these codes 0500,0753,0713,0460,1763,1693,0177,0602. I think maybe the tranny is toast. what do you think it could be.
Old Mar 5, 2007 | 07:10 PM
badme's Avatar
Thats alot of codes. Fix the codes and the surging will probably go away. I would guess that all of those codes are related and one fix will fix all or most of them.
Old Mar 5, 2007 | 07:15 PM
Twodiesels's Avatar
I honestly dont know where to start.
0177 water in fuel
1693 companion code
0460 no fuel chang over time
0602 fuel calibration error
Those I think I can do. The others I don't know. I know what they mean.
I am no expert mechanic.
Old Mar 5, 2007 | 08:32 PM
matthopp's Avatar
0500- Speed senson, basically like spinning your tires.
My truck is getting 0500, 1693, 1694. I dont know if i would call it surging, but it feels like my foot falls off the pedal when driving. Still researching.
Old Mar 5, 2007 | 08:52 PM
Twodiesels's Avatar
My rpms go up and down while it does this.
Old Mar 5, 2007 | 09:16 PM
matthopp's Avatar
engine rpms or tach only?
Old Mar 5, 2007 | 09:23 PM
Twodiesels's Avatar
Both! It does feel like foot slips off peddle. I am wondering in the vss can cause the other codes. I had the rear vss replaced about a 2 month ago. Engine sounds fine>
Old Mar 6, 2007 | 07:20 AM
badme's Avatar
0177 water in fuel
1693 companion code
A good start is to check all the grounds.
Old Mar 6, 2007 | 08:29 AM
country4x4kid's Avatar
Might be the injectors that you have installed, i have heard that alot of had similar issue and it all seems to be after they put injectors in.
Old Mar 6, 2007 | 09:12 AM
Twodiesels's Avatar
I doubt its the injectors. They have been in for 1.5 years. Will check though.
It feels like it is defueling and then fueling again. What grounds should I check and where are they?The 0713,0753,1763,0500 I think have got to be related some how. Seems to only do it after the truck comes up to temp.
Any input please
Thanks
Old Mar 6, 2007 | 09:28 AM
If i remember right there is green wire on the fass system that is the ground. Give that a check.
Old Mar 6, 2007 | 09:33 AM
Twodiesels's Avatar
will do thank you
Old Mar 6, 2007 | 12:21 PM
Twodiesels's Avatar
Well i cleaned the batteries. Lots of corrosion. I also wrapped the black wire in foil. I hope this help, but I am not holding my breath. I am resetting the apps right now.
I'll keep posted
Old Mar 6, 2007 | 12:22 PM
let us know im intrested to find out what it is
Old Mar 6, 2007 | 12:37 PM
Twodiesels's Avatar
Isn't there a speed sensor on the tranny, as well as the diff. Where is the one on the tranny located?
Thanks
