Trouble Brewing
Old Feb 27, 2008 | 12:07 PM
mschefter's Avatar
Trouble Brewing
I work in northern alberta for the summer season, and the other day had to do my 13 hour trek north from calgary. Any way I was driving along and about 5 hours into the trip I had loss of power but still some throttle response. Then as quickly as it came it disappeared. I didnt think anything of it until a couple more hours into the trip where it started again but this time it was going back and forth several times. I pulled over at all small town and shut it down to cool, started it up and continued on my way and seemed okay until a couple hours from my destination where the lose of power came and stayed. I had to complete the trip with pedal to the floor and top speed of about 90km. I do have a fuel pressure gauge and was indicating okay and no engine light came on. I have talked to the dealership and are clueless as to my problem, so I was hoping somebody here might know what the problem is. By the way I drive a 2002 2500 cummins diesel. Any help is greatly appreciated.
Old Feb 27, 2008 | 12:10 PM
AlpineRAM's Avatar
Did you check for codes (can be done with the key- simply cycle the cey from off to on 3 times without starting the truck, codes will be displayed in the odometer)
AlpineRAM
Old Feb 27, 2008 | 12:24 PM
mschefter's Avatar
I have not done that yet, I always figured that there are no codes if the check engine light does not come on. But ill diffidently check it out as soon as I can.
Old Feb 27, 2008 | 12:39 PM
MikeBC's Avatar
Sounds just like my dead pedal, you will not like what fixed mine
Vp44
Check for codes, they will tell you
Old Feb 27, 2008 | 03:45 PM
marine4life's Avatar
Ahhhh crap, another VP Victim. Man, if I could catch the guy responsible for the design of these junk pumps I would rearrange his face
Old Feb 27, 2008 | 04:31 PM
buba1960's Avatar
I also have had the same experience as youve described.
I limped to my dealer where my truck(2002 also) has been for 2 weeks now.
They replaced the lift pump first,then the injection pump next.Still the same symptoms,runs abit then heistates and shuts down.NO Codes at all?
Theyve downloaded the computer and sent it to Dodge Canada Tech division and are awaiting a reply.They only good thing is its all warranty so far.
Good luck
Old Feb 27, 2008 | 05:12 PM
MikeBC's Avatar
Buba, did they put the old vp back in by mistake - lol
Have they tried a new boost sensor?
Keep us up to date
Old Feb 27, 2008 | 06:06 PM
Number47's Avatar
just a little note to every one CEL (Check Engine Light) only comes on if its a emission related fault.
Diesel-Dan
17
Oct 17, 2006 06:49 PM
trik396
Jun 10, 2006 05:50 PM
