Transmission Not Shifting
Old Jun 16, 2008 | 09:11 AM
BSPENCE10's Avatar
Transmission Not Shifting OUT OF 1ST
This Morning Truck Will Not Shift Out Of 1st.did Not Have Any Promblems When I Parked It Last Night.fluid Is Fine And Will Go In Reverse Fine.just Wont Shift Out.also Abs Light Is On.IT is 98
Old Jun 16, 2008 | 10:43 AM
BSPENCE10's Avatar
Unhappy
Any Ideas
Old Jun 16, 2008 | 10:45 AM
vzdude's Avatar
DTR's 'Go to Guy'
Any codes? Check engine lamp? Does the speedo work? Could be several things, but without any info other than it won't shift, anything would just be a guess. Rear Diff speed sensor, trans output speed sensor, numerous other electrical issues could all be the culprit.
Old Jun 16, 2008 | 11:21 AM
BSPENCE10's Avatar
Check Light Is Not On.the Abs Light Is On And Hasnt Been Before This Promblem.SPEEDO WORKING FINE.
Old Jun 16, 2008 | 11:28 AM
vzdude's Avatar
DTR's 'Go to Guy'
Yeah....anything would just be a guess without having some codes. Have a local shop read the abs codes and go from there. They very well could be related. Check all the fuses and connections first. Keep it simple, then get the codes read.
Old Jun 16, 2008 | 12:39 PM
tx_2500's Avatar
<-- Speaking from exact same experience.
Save all that trouble and go down to the dodge dealership. Ask for the sensor that goes in the side of the transmission (I think its the output speed sensor, but regardless its the only one). Its around $30 IIRC. Crawl up under your truck on the drivers side and look at your trans housing. Youll see it. undo the clip and back out the old sensor with a crescent wrench or something. There will be a little ATF comming out, just have the new sensor ready. Ill bet you a case of beer that fixes it instantly.
Old Jun 16, 2008 | 12:43 PM
BSPENCE10's Avatar
the truck is at the house.shop is about 20 miles away.
Old Jun 17, 2008 | 10:38 AM
gooseman495's Avatar
A common thing on that trans is govenor transductor and solinoid goes bad.You have to drop the trans pan to get to them.
Old Jun 17, 2008 | 01:02 PM
Dinner's Avatar
Yup, that's what happened to my tranny. Wouldn't shift out of 1st unless I revved it way up and let off the accelerator. I ended up putting in a new valve body from Goerend, so I'm not sure how much the Transducer and Solenoid is..
Old Jun 17, 2008 | 02:02 PM
tx_2500's Avatar
I think that the gov sensors might be out, which is why im having trouble shifting on mine...but still on his, its the transmission speed sensor. The ABS light confirms this
Old Jun 18, 2008 | 12:38 PM
Dinner's Avatar
Just because the ABS light is on doesn't mean the tranny won't shift. My parking brake light is on, ABS light is on, and my speed sensor in my tranny doesn't work either, so I have no speedo or odometer. My tranny will still shift good and normal.
Old Jun 18, 2008 | 01:11 PM
vzdude's Avatar
DTR's 'Go to Guy'
vzdude is sitting back .......waiting on definative diagnostics......codes are the only way to know for sure what could be causing the issue......and then .....the code will only point a technician in the right direction to do further diagnosis.......nothing is ever cut and dry....trust me.......
Old Jun 18, 2008 | 01:16 PM
tx_2500's Avatar
^ you can argue with me all day till your blue in the face but you better bring a sack lunch. I never said just because his ABS light is on his truck wont shift. Having the transmissions speed sensor out also sets off an ABS light. I had the EXACT same thing happen. I parked the truck, came back out and it would not shift all of the sudden AND had the ABS light on. I went to the dealership after searching on here for my problem and replacing that dinky $30 sensor in 5 minutes instantly fixed everything. ABS light went away and trans shifted just as it should have.
Old Jul 11, 2008 | 09:41 PM
ramlovingvet's Avatar
DTR'S Chaplain
Where is the rear diff Sensor located?
Thanks Guys.
Old Jul 12, 2008 | 04:49 AM
smokinram99's Avatar
on top of the diff case, but I think it's only for the MANUAL trans....exactly guys??? AUTO has the speed sensor on the output, driver side...
