transmission mods?
Old Jan 1, 2003 | 08:52 PM
tlea7's Avatar
transmission mods?
Hello everyone, I am new to the board, thanks in advance for your help. I have an 02 2500 4x4 and am considering adding 275 injectors and an EZ edge. What transmission modifications, if any, should I be considering? Also how hard is it to change the injectors? As far as warranty, if there was a trans problem would the dealer actual check the injectors to see if they were not oem?
Old Jan 1, 2003 | 09:46 PM
DPG's Avatar
DPG
Re:transmission mods?
tlea7:<br><br>Welcome! You will find a lot of very knowledgeable people here that are willing to share. If you are going with injectors and and EZ, I would deffinately upgrade the tranny. I am assuming that you have an automatic? I would get at least a Torque Converter and Valve Body. I have DTT equipment in my tranny and I am very happy with it. There are also other people out there with good trans. products ATS, etc. I think most of the guys here have either DTT or ATS. I wouldn't worry about the injectors at the dealership, but you will want to remove the EZ for sure, when you go in for service. As far as changing the injectors, it's not something I would tackle, so I really don't know how hard it would be. <br><br>Good luck with your new truck!<br><br>DeWain
Old Jan 2, 2003 | 07:47 AM
AlpineRAM's Avatar
BBD- Why did you have to replace the wiring harness? inside or outside of the tranny?<br><br>Thanks<br><br>AlpineRAM
tristan21
Jun 19, 2007 04:57 AM
MikeyT
Jun 9, 2006 06:20 PM
acook
Jun 1, 2006 05:40 PM
