Transfer case front shaft bearing.
Old Jan 1, 2013 | 09:25 AM
snowjoker's Avatar
Can this bearing in my 99 auto be replaced from the outside ? If so , does anyone have a part number for it ? Its pretty lose.. This is where the front drive shaft bolts onto the flange, bearing.
Old Jan 1, 2013 | 12:12 PM
gorms's Avatar
No the retaining ring is on the inside of the case, so it needs to come out and be split. Not a very hard job, getting the flange off the shaft might not be easy. Take a close look at the drive chain, may have stretched over time with a bad bearing. It should fit the gear tightly, you should not be able to pick any slack up off the teeth easily. Good luck.
Old Jan 1, 2013 | 02:32 PM
snowjoker's Avatar
Where do I get the parts ? I guess thats tomorrows project is order the parts and yank the case out before the next snow...
Old Jan 1, 2013 | 05:20 PM
gorms's Avatar
Either dealer, quad4x4, drivetrain.com, maybe even napa? The diagram I posted above is from drivetrain.com.
Old Jan 1, 2013 | 06:52 PM
snowjoker's Avatar
Ok thanks !
Ram1999
May 4, 2008 03:49 PM
qwest
Jul 21, 2007 10:38 AM
DEC
Sep 29, 2003 09:47 AM
