Trans Temp Light
Old Aug 16, 2007 | 06:15 AM
DeTree's Avatar
Question Trans Temp Light
Recently, and it only happens occasionally, my trans temp light comes on at hi way speed for a second or two and the goes out. I have two trans temp gauges and both say I am at 145 degress.....any ideas what is causing this?
Thanks in adavnce
Old Aug 16, 2007 | 08:55 AM
glenn-k's Avatar
Where are your sensors located?
If one is not in the line coming from your torque converter to the back end of the heat exchanger you may not be seeing full heat. It is the line that has the check ball in it that needs to be removed for full flow to the cooler. If you do that you will experience about 30 seconds of waiting for the torque converter to fill but you need that for the turbo to heat up anyway.
There could be other reasons for the light. Bad sensor -short?
Old Aug 16, 2007 | 07:24 PM
phox_mulder's Avatar
Trans Temp light is supposed to come on at temps of 280 or thereabouts.
I'd say you have a short, or bad factory sensor.
phox
Killer Infidel
Aug 28, 2014 10:25 PM
hconstantino
May 3, 2010 12:15 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
FD5
Apr 3, 2008 05:55 AM
