Torque Converter "Shudder"
Old Aug 10, 2004 | 08:57 AM
Mcmopar's Avatar
Took a 1500 mile trip this weekend, towing a trailer that was about 7000 lbs. I noticed the RPM's increase slightly under acceleration on a hill with the TC locked up, in both drive and OD. On the way home it did the same thing and also started to shudder. I guess it would be fair to call it moderate acceleration. It doesn't do it under light acceleration. Any idea's on a fix?
Original tranny with 108K. I have an EZ, AFE, and 4" exhaust, everything else is factory.
Old Aug 10, 2004 | 04:12 PM
Smokee's Avatar
You can try boosting the line pressure. DOing that might save you for awhile.
Old Aug 10, 2004 | 04:26 PM
John_P's Avatar
Phil:
That "shudder" you describe is not good!! It is most likely
your torque converter "beginning" to go. I had it my 1996
Dodge CTD and let me tell you it will only get worse buddy!
Sounds to me like you need an ATS TripleLok like we talked
about a few months ago. You can try raising the line pressure
like "Smokee" said, but it is only a "temporary" fix. If your TC
is going bad that extra heat is going to get transferred to
the clutch packs and seals so don't wait to long.
Good luck!
John_P
Old Aug 10, 2004 | 05:09 PM
Mcmopar's Avatar
Thanks guys,
I am going to raise the line pressure this weekend, and start saving money for the "impending" upgrade!! So what's up John? did Johner get his "envelope"? I hope!
Old Aug 10, 2004 | 07:22 PM
j-fox's Avatar
Raise the line pressure 3-4 turns and get fresh fluid in it.
MOST likely it is slipping the 3rd gear clutches. Also called direct clutches.
Good luck with it.
Old Aug 10, 2004 | 10:00 PM
J BODY's Avatar
Mine did that about six months ago pulling the race rig. I put a new torque convertor in (another stocker....warranty). The front of mine was the prettiest purple and blue right where the lock up clutch is.
Old Aug 10, 2004 | 10:01 PM
bigthumper's Avatar
how do you raise the line pressure mines doing the same thing.. i plan on getting a converter and VB very soon..
Old Aug 11, 2004 | 08:42 PM
John_P's Avatar
Phil:
Your plan sounds good.....and yes, Johnner got your
envelope! Thanks and good luck with your truck buddy.
John_P
Old Aug 11, 2004 | 09:22 PM
Floorman's Avatar
ah ha got an ez and werent going to tell me? i"ll even bet you were going to say something like she running good todayyyyy wannna run it oh yeah sure well ol dan tried that in ct jumped me but took a royal beating and then he said he just pulled over to let me by while laying rubber. did you order yourself a new turbo master too?
Old Aug 12, 2004 | 02:44 AM
addecus's Avatar
yeah that's what it's doing, it is downshifting. hey by the way, do you have any problems pulling your boat up the ramp in 2WD or do you always use 4WD ?.
Old Aug 12, 2004 | 07:56 AM
J BODY's Avatar
I use 4 low to pull the boat out. Makes it much easier.
Old Aug 12, 2004 | 08:25 AM
Mcmopar's Avatar
Floorman,
Well, humm, let me think, I got a BIG turbo, BIG injectors, another computer, and some other stuff!! OOPS, I mean I borrowed the EZ, everything is as you last saw it!!!!
mskibo
Jul 17, 2009 06:23 PM
Rafter B
Apr 13, 2008 09:40 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
mainer
Jul 17, 2007 07:13 PM
edge600
0
Jan 9, 2006 08:09 PM
