tips and tricks
Old Apr 25, 2009 | 05:05 AM
polaris800sp's Avatar
tips and tricks
anyone have any tips/tricks to make changing the oil easier?
Old Apr 25, 2009 | 06:07 AM
wilsonoo56's Avatar
The only thing I do is run amsoil and change it every 12 months or 12 thousand miles per the amsoil manufacture.
Old Apr 25, 2009 | 07:29 AM
Doj Dewd's Avatar
fumoto oil drain plug - do a search on here and google it.
geno's sells them also
Old Apr 25, 2009 | 07:37 AM
Doj Dewd's Avatar
remove the air intake tube (especially if aftermarket) to make it easier to remove the filter.
use a 'jaw' type filter remover, or punch a screwdriver thru the side and turn to remove.
Old Apr 25, 2009 | 09:39 AM
D2 Cat's Avatar
Yes, the fumoto drain valve. Saves the mess. Easy to draw off oil for samples.
Old Apr 25, 2009 | 12:00 PM
DieselNomad's Avatar
i fill the filter just about full, then set it close to the filter housing.then slid under the truck and thread my arm up and screw the filter on from underneath.works the best for me, hope it helps.
Old Apr 25, 2009 | 12:55 PM
lovinCTD59's Avatar
Fumoto drain valve.... Any letting your truck sit for a while before you change your oil will allow time for the oil in the filter to settle so you dont have it running all over when you screw the filter off...
Old Apr 25, 2009 | 01:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Slip a gallon size ziplock bag over the filter after you initially loosen it....but before the oil starts flowing out around the top.
When it drops free of the stud, you can remove the filter and all the (now contained) oil without dousing the right side of the block with waste oil.
Simply zip the bag closed and dipose.
Old Apr 25, 2009 | 11:40 PM
Tate's Avatar
Just an addition to this, do this when the filter is cool. I made the mistake of doing this when it was still toasty and melted the bag, made a bigger mess than if I had done it without a bag and just removed it straight out.
Old Apr 26, 2009 | 08:52 AM
sheriffav8r's Avatar
Change the oil on your neighbor's driveway.... :-)
Old Apr 26, 2009 | 10:02 PM
Thundercraft's Avatar
That's funny. A good idea, but funny.
Old Apr 26, 2009 | 10:17 PM
HotRodTodd's Avatar
657,633 on the 02 as of tonite, and now you guys tell me to change the oil !
Sheesh
Old Apr 27, 2009 | 10:30 AM
clowndodge01's Avatar
Then when u get done filter the used oil and dump it in the fuel tank, been doing it for 2 years now no probs, just make sure when u do it your at the fuel pumps so u can fill up with diesel and mix everything up. I do a mixture of 3 gals used oil to a full tank top off of diesel. then u dont have to worry about used oil in 10 different containers all about the yard.
Old Apr 27, 2009 | 12:32 PM
klx650a2's Avatar
I've got the EZ CHANGE DRAIN PLUG on my truck. Super clean way to change oil, I just let it drain overnight and the zip lock bag over the filter works great when the filter is cool.
Old Apr 27, 2009 | 05:25 PM
FFmike's Avatar
If no drain valve, wear latex exam glove when pulling plug. Good habit of gloving-up as EMT for twenty years pays off at home. Also, instead of using pricey zip lock bags for filter, I just get plastic grocery bag that has no holes in it. Does the same thing.
