timing the engine, cam crank and ip
iam finally putting the engine back together but it been too long and i forget how to set the timing for the cam and IP. The only thing showing up in searches is about pump timing. thanks
On the crank rotate untill you are at tdc cylinder #1-the dot on the crank gear is about at the 1 o'clock spot. The cam gear has 2 sets of dots, alighn the pair of dots on cam gear with single dot on crank. The ip gear has 2 dots. Aline these with the single dot on cam gear.
Make sure you are at tdc #1 and not tdc cyl#6. You can pull the valve cover and verify this.
92smokin blacky
Feb 28, 2011 02:36 PM
etn550
Apr 1, 2010 12:12 PM
Snoxracer
Jul 10, 2007 02:23 PM
