Thread sealant + diesel
Old Oct 13, 2005 | 12:50 AM
darrenG's Avatar
So, i've narrowed down my hard starts (again) to a diesel leak that's coming from my fuel pressure sending unit. To make things easy, let's assume I can't screw my fuel pressure sending unit in farther. Is there a thread sealent tolerant to diesel fuel? I have abstained from teflon tape, as gasoline eats away and gets clogged by it.
What can I use to seal threads on diesel?
Old Oct 13, 2005 | 05:54 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Try this stuff.
Permatex® High Performance Thread Sealant
OEM specified. Formulated specifically for metal, tapered pipe thread fittings, High Performance Thread Sealant replaces Teflon® tape and pipe dopes. Cures rapidly to withstand 10,000 PSI. Perfect as a replacement for Vibra-Seal® pre-coated parts. Prevents galling and protects mated threaded areas from rust and corrosion. It is certified to ANSI/NSF Standard 61 for use in potable water systems.
Suggested Applications:
Stainless steel fittings, head bolts into through holes, oil PSI sending units/sensors, oil and coolant lines, intake manifold switches, rear axle fill plug, fuel fittings
Old Oct 13, 2005 | 08:07 AM
RustyJC's Avatar
Assuming you have good threads, Permatex #2 (non-hardening) also works well. It's been used in the oil patch as long as I've been around (and that's awhile )
Rusty
Old Oct 13, 2005 | 09:37 AM
infidel's Avatar
Rusty
Strong second to what Rusty said.
You'll have no problem finding the #2 at any autoparts, the stuff Ed recommended while good may be harder to come by.
I have a farm diesel tank that seeped fuel, tried all kinds of different sealants for several years (could only reseal when the tank was empty, which I didn't really want either)
Permatex #2 finally fixed it, it's been at least 15 years without a drip.
Old Oct 13, 2005 | 10:01 AM
Scotty's Avatar
Top's Younger Twin
Gasoil Teflon paste works well too.
Scotty
Old Oct 13, 2005 | 10:59 AM
darrenG's Avatar
awesomeness. I will try this today or tomorrow, whenever there be time.
thrashingcows
Sep 26, 2013 10:41 PM
fire-fool
Mar 17, 2011 07:04 PM
whiskeyrichard
Feb 22, 2009 05:35 AM
JohnnyH
16
Sep 26, 2007 10:34 PM
billmac
Feb 18, 2006 10:34 AM
