suspect lift pump
Old Aug 13, 2012 | 04:12 PM
pwregan's Avatar
suspect lift pump
Would a dead lift pump throw a code and which one?
truck ran fine yesterday and today it started for a minute then died and will not restart- i used to hear an electric humm in engine bay which i thought was the lift pump and it is silent now- which leads me to believe it is the problem.
any advice is greatly appreciated- thank you
Old Aug 13, 2012 | 07:07 PM
johnh's Avatar
my first lift pump failure did not show any codes, it was inoperative for who knows how many miles. i discovered it when i changed the fuel filter for the first time. an acceleration stumble was the only performance issue...the check ball spring broke,
the pump still would run but would not pump
Old Aug 14, 2012 | 06:51 AM
j-fox's Avatar
Put a gauge in the cab.
All 98.5 thru 02 must have it.
No it won't set a code, it just ruins the VP44.
Old Aug 17, 2012 | 11:01 AM
mpfireman's Avatar
Lift Pump
My lift pump went out at 100,000 miles, the motor started, then just quit. I was lucky that the VP 44 pump was not damaged. Had the external lift pump replaced with an after market brand, and everything has run fine for the last two years.
98.5 Ram Quad cab HD 2500.
ray man
Jul 21, 2011 03:37 PM
fastlane
Oct 5, 2010 04:28 PM
Denis
Mar 30, 2004 11:03 AM
kingcompanyceo
Nov 21, 2003 05:41 PM
fishermansteve
Apr 13, 2003 09:22 PM
