surging/stumbling upon pulling out of park . . .
Old Jan 11, 2010 | 09:25 PM
Doj Dewd's Avatar
looking for some help here . . . regarding truck in sig.
upon pulling tranny out of park and into reverse or a forward gear, so ANY gear - the engine surges and stumbles like it is about to stall and usually gets back to a smooth idle after 3-5 stumbles. i can make it go away if i return to park.
this usually occurs, and i can make it do it if i bring it out of park right after startup, but still sometimes occurs if it has been idling for a while in park.
any ideas on what this may be? i have only noticed this for the last few months to a year. it happened with the STOCK LP and it is still happening with the MITUSA PUMP (in case you are thinking it may be the LP)
I am thinking it is either the tranny or the VP44 going bad. never used to have this problem, and my habits/routines of starting/shifting have not changed at all.
looking forward to hearing what ya' got. need more info? just ask!!
Old Jan 12, 2010 | 12:03 PM
Twogun's Avatar
Codes?
Try turning your ignition key on and off three times, any codes should come up on the mileage screen. Do not engage the starter. Twogun
Old Jan 12, 2010 | 02:56 PM
Junk Man's Avatar
Key frequently doesn't give all of the codes. Get it scanned - all of the chain stores loan scanners. It is likely a sensor.
Old Jan 18, 2010 | 08:16 AM
Doj Dewd's Avatar
thanx, i will check into this.
Old Jan 20, 2010 | 08:30 PM
Doj Dewd's Avatar
turned the key trick and got:
P 1693
Old Jan 21, 2010 | 05:09 PM
Tazman's Avatar
Doj Dewd,
Have any luck with this yet?
My 98 just died after surging at a traffic light with similar symptoms.
taz
Bama_Dude
14
Apr 20, 2006 09:06 AM
dslsmoker
Nov 19, 2005 03:55 PM
alltimelow1
Apr 6, 2005 07:28 PM
99 cummins
Oct 30, 2004 09:33 PM
sixtogo
Nov 21, 2002 10:23 PM
