surging engine idle
Old Apr 2, 2010 | 06:15 PM
birddoctor's Avatar
surging engine idle
My truck is idling real rough.It sounds like its "camming" The tach needle jumps around alot.I was backing up our camper and it was so rough it made my low pressure chirp go off.The fuel pressure stays at a constant 15 to 16.Now going down the road I have no problems at all,plenty of power.I had the valves adjusted and the injectors popped and reset about 3 weeks ago.Thats when the rough idle started.Anybody got any ideas???
Old Apr 3, 2010 | 02:00 PM
birddoctor's Avatar
Surely there's somebody here that can answer this.
Old Apr 3, 2010 | 08:52 PM
dezl-andy's Avatar
did they change anything on the pop off press?
Old Apr 3, 2010 | 09:00 PM
birddoctor's Avatar
Yes he shimmed a few of them.He said they were supposed to be within 50 lbs of each other.
Old Apr 3, 2010 | 10:14 PM
nitrousn's Avatar
Unhook your edge and see what it does. If ok than its in the edge box. If not I suspect a possible to tight adjustment.
Old Apr 3, 2010 | 10:58 PM
birddoctor's Avatar
Ok i will try that.Unhook the edge from where?The edge box itself? or the computer on the engine? If its a tight adjustment,will it get better? Will it hurt anything. My engine is really quiet now after the adjustment and man does it have power!!
Old Apr 5, 2010 | 04:06 PM
birddoctor's Avatar
bump
smokinblack
Mar 26, 2006 01:35 AM
spitzair
Jan 30, 2006 04:53 PM
APD
Mar 3, 2005 05:39 PM
sparky76266
Apr 2, 2004 09:28 PM
sparky76266
Feb 13, 2004 05:25 AM
