Strange LP Pressures...
Ok... I got a few question for the LP / VP44 Guru's...
I've got my cruise set for 65 MPH on flat ground and my boost is not changing. But the LP pressure is dropping to 10 PSI then rising back 12.5 PSI then falling again... Cycle continues randomly.
CURRENT PSI NUMBERS
16.5 - Starter Bump - This number has gone up 1.5 PSI since new...
14.5 - Idle - This number has come up as well about 1 PSI
12.5 - 10.0 - Cruise set @ 65 MPH flat ground
7.5 - WOT - No change here...
1. Is this a sign of failing LP? Even though it passes the volume test.
2. Is there a pressure regulator on the VP44 that could be causing the problem?
This is just plumb strange to me... Ok Guru's go for it! Tell me what you think???
CURRENT PSI NUMBERS
LP is dying. IMHO
Answer to number 2 is yes. Its internal in the LP. Suspected of being the largest cause of failure, and my theory is the engine vibration damages it.
If you get a new one take the old one apart.
Originally posted by P.J
Should this effect my TOM vote??? Does the winner have to be a running truck?
Just kidding buddy!
Just kidding buddy!
Oh! Am I in the TOM list???
I really don't want to drive all the way down to the dealer yet... I think I will let it delevope a bit more before I run for the dealers...
O.T
Sep 18, 2007 12:50 PM
toupee
Jun 27, 2007 04:19 PM
Push Rod
Dec 26, 2002 03:31 PM
