starting problims
Old Jun 19, 2007 | 04:53 PM
dodge_fan's Avatar
Question starting problims
I have a`2001 ram with a 24 valve i am having a hard time starting i have already replaced the lift pump, fuel filter, injectors, and all the o-rings
I am still having the same prob. any information, ideas or tricks to find out whats going on I would appreciate it
my fuel pressure is 14 psi
Old Jun 19, 2007 | 06:34 PM
Dinner's Avatar
What is it doing when you crank it over..does it crank over...does it act like it's not getting any fuel? Where is your fuel pressure gauge reading the pressure?
Old Jun 20, 2007 | 09:02 AM
RowJ's Avatar
Is the problem when engine is cold....or after a short stop somewhere? Two very different scenarios... with possibly different causes!
RJ
Old Jun 20, 2007 | 03:53 PM
dodge_fan's Avatar
I can crank it for a about 30-45 seconds before it will fire the fuel guage is between the IP and the filter
I have the problim all the time whether it is cold or after it has been running it dosnt seem to change
Old Jun 20, 2007 | 08:31 PM
blackdiesel's Avatar
Registered
Have you checked for codes?
Old Jun 21, 2007 | 11:49 AM
claw1's Avatar
starting problems
I have a 98.5 . Went camping for a week returned friday. The problem with my trip was when I got to the campground the truck wouldn't start. The injection pump went out. So the only place that would fix it was a dodge dealer but had to do the lift pump too for warranty. Anyhow back to your problem, truck parked since Friday went to us it yesterday wouldn't start. Got my friend at local garage to bring up his snap on scanner no codes were present everything checked ok. We were looking @ the info in the scanner on hard starting after sitting he went to crank it and it started right up. Scanner troubleshooting says return line to tank could be leaking and air backing up to injection. I'm going to check my lines tonight.
Old Jun 21, 2007 | 12:37 PM
Registered
Theres a check valve on the banjo bolt on the return line. take it off and see if you can blow through it.
Old Jun 21, 2007 | 06:22 PM
dodge_fan's Avatar
no codes but where do you blow through it should it go one way or not either
Old Jul 3, 2007 | 05:55 PM
dodge_fan's Avatar
well I got it fixed after new IP, LP, and injectors it runs and starts with no problims
thanks for all the help
LP 120
IP 1600
Injectors Bosch 300horse 600
haveing aa truck that runs = PRICELESS
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Commatoze
Sep 3, 2006 02:30 PM
admin
16
Aug 17, 2003 10:07 AM
