Starter Removal
Old Aug 6, 2005 | 11:06 AM
cr1998's Avatar
Starter Removal
Getting ready to replace the contacts in my starter with these
Starter Contacts
Anything special I need to know on pulling the starter?
Thanks,
CR
Old Aug 6, 2005 | 11:08 AM
Dr. Evil's Avatar
you will need a 10mm 12 point socket for the starter bolts - top bolt is a joy - have fun .
Old Aug 6, 2005 | 11:16 AM
Vulcan's Avatar
Yup, Larry B's are the way to go, did mine last year and no problems since. Those little 12 pt bolts are a *&%$# to get off. Other than that no prob.
Old Aug 6, 2005 | 12:34 PM
infidel's Avatar
I've ended up using a small hydraulic jack to turn the wrench on a couple of them
Old Aug 6, 2005 | 12:38 PM
sherod's Avatar
That top bolt is a PITA. First time I took it off, went thru 3 sockets before I finally broke it loose.
Reminds me, it's time to check it.
Good idea on the jack!
Ed
Old Aug 6, 2005 | 07:48 PM
J BODY's Avatar
If you're lucky someone may have removed them prior to you....if not you are in for a treat. I've had to do the bottle jack trick myself on those.
Old Aug 7, 2005 | 09:20 AM
Wolfeman's Avatar
I used 12mm box wrench about 7" long ( Sears ) and a 12" length of pipe to get the top bolt. I was able the get the wrench on from the bottom and then the pipe from the top and got it loose. A real PIA but doable.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
Billfisher
Dec 15, 2002 07:32 AM
