Starter again
Old Dec 23, 2008 | 09:06 PM
AlanF's Avatar
Starter again
Two weeks ago replaced my starter with a new not rebuilt unit. Heading home after Christmas shopping and nuth'in. Not even a click. Weather is gross, 1 foot of snow and hovering around zero.... think lying down on a slurpee matress. I tried to jump the solenoid from the starter lug and still nothing. I whacked the solenoid but still no action. Got to go to Vancouver Island tomorrow to visit Mom, will have to fix it when I get back. Hopefully it will warm up a bit as it is going to be a roadside repair. I will check to make sure I have 12 at solenoid wire when keying starter before I pull the starter. Any suggestions for troubleshooting? Thanks for any help.
Alan
Old Dec 23, 2008 | 09:33 PM
Junk Man's Avatar
Rule out battery, cables, wiring & switches first. Make sure batteries are charged (12.7 = full) & cables are clean & tight (use meter & measure voltage drop.) With key to start & you should have full battery voltage to the small terminal on the starter. If not, you can run a wire from + battery terminal to starter. There is a switch on the clutch pedal or tranny if you have auto. Check a wiring diagram or it may be marked on the fuse box cover. If that all checks out, pull starter & bench test. Look at contacts in solenoid but they should be good if it's new.
Old Dec 24, 2008 | 11:34 AM
Dinner's Avatar
Friends truck (gasser) was doing the same every now and then. Wouldn't even click, etc. Turned out to be his battery cables were a little loose. One day we were in town and it wouldn't start so I just moved the battery cables around and it started.
Hopefully yours is something this easy, good luck!
Old Dec 24, 2008 | 02:33 PM
J.Suplanski's Avatar
Unhappy Starter
Where did you buy the starter? Hope its not made in China!
Old Dec 24, 2008 | 03:08 PM
Busboy's Avatar
I notice you have a transmission temp gauge so you must have an Automatic. Have you tried starting in Neutral?
Old Dec 24, 2008 | 06:02 PM
AlanF's Avatar
Starter
I bought the starter from the local auto parts outlet, wasn't much more than a rebuilt starter so I bought it. Don't know where it was manufactured, I will look at the warranty card when I get back home. I did run through the trans selector when it wouldn't start, will it start in neutral? Happy holidays everyone.
Alan
Old Dec 25, 2008 | 11:22 AM
D2 Cat's Avatar
Yes, it will start in neutral (if everything else is correct)
FMB
Nov 14, 2010 09:09 PM
Steven K
Jun 4, 2009 10:32 AM
buckman361
Nov 13, 2008 09:54 AM
b84u
Feb 20, 2006 01:04 PM
Paradise Racing
Jan 18, 2005 09:08 AM
