Setting Transmission related codes
My truck keeps setting codes 0622, 0753, 1693, 1765. I changed the solenoid & still sets them. I have a DTT smart controller & DTT upgraded tranny. This set up has worked fine for years, but now something is going on. Any ideas?
Thanks
jack
Thanks
jack
First thing I would do is check your trans connector and wiring harness. Look for corrosion or chafing of the wires all the way up to the PCM
This is assuming you have seen no other weird issues.
No other real issues. I reset the codes and truck run fine, but shortly after I can sense that I'm not getting full power. Check & codes are back. I will check connectors & grounds see if that helps. Thanks for reply. Keep thoughts coming please.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
