riends 24 valve knocking?
Old Jan 20, 2011 | 11:33 AM
bigwheels94's Avatar
Friends 24 valve knocking?
Hi all. I have a friend that has a 24 valve in his dodge that suddenly started knocking while pulling his trailer over a pass. I can hear it's the #4 cyl. It sounds like it's in the top end, as opposed to a rod brng. I'm going to pull the injectors, & have them tested, & put my bore scope in to look @ the cyl walls, & piston. And I'll run the overhead set to look for any valve problems. My questions are:
1- Will my Smarty S06 read any codes in this engine?
2- Are there any known issues that I'm not aware of that I should be looking for?
Thanks. Not familiar with the VP44 system, but I'm certified on the common rail.
Old Jan 20, 2011 | 11:37 AM
SIXSLUG's Avatar
Sounds like an injector.
The Smarty pulls codes but I am not sure there is one for a bad injector.
There are ones for the vp but mostly just for voltage and timing issues.
Old Jan 20, 2011 | 11:41 AM
Thanks sixslug. I'm not expecting a code for the injector, but the CEL came on when it happened, but has since gone out, so I want to see what it was. I'm suspecting a blown nozzle, but want to know if there's anything in particular with the VP44 system I should know about.
cLAYH
33
Nov 11, 2008 09:22 AM
normht
Feb 4, 2006 10:23 PM
wantabee
Mar 14, 2004 09:22 PM
BamBam
41
Sep 19, 2003 09:48 PM
BamBam
Feb 24, 2003 02:43 PM
