Rear suspension difference between 4x4 and 4x2
Old Sep 6, 2011 | 09:19 PM
Pinkston's Avatar
What is the difference in the rear suspension between a 4x4 and 4x2. Are the blocks different heights? Different spring pack? Number of leafs?
Old Sep 7, 2011 | 07:04 PM
gorms's Avatar
I'm pretty sure the only difference is block height. The 4-by's get a hefty block (at least 4-6"), 2wd not so much. That is assuming your comparing two similar trucks, like 2 2500's or 2 3500's, or 2 2500's with camper packages...etc.
Old Sep 8, 2011 | 01:40 AM
bcbigfoot's Avatar
My 2wd has a spacer block that is a little under 1" and the 4wd trucks I believe are 4".
Old Sep 8, 2011 | 05:48 AM
Break Away's Avatar
Also check the width of the springs - my 4x4 is three inches.
Old Sep 8, 2011 | 08:59 AM
alan96's Avatar
If the only difference is the block would their be an issue with removing the 4x4 blocks and installing the 4x2 block to lower my ride height?
Old Sep 8, 2011 | 09:04 AM
Purplezr2's Avatar
May cause reverse rake when you load it, I would assume you would be either level or have a slight reverse rack with out the load.
Old Sep 8, 2011 | 05:40 PM
Pinkston's Avatar
Seems like there are different packages. My 3500 has 2 overload springs. Saw a 3500 yesterday without them. I picked up a chassis with springs yesterday. It was a 98 2wd service truck. It actually had the same blocks as my 4wd, had the 2 overload springs, and even had 2 extra leafs in the pack. Even though it is from a 2wd I think it will work great for what I need.
Old Sep 9, 2011 | 03:10 PM
drafalske's Avatar
Someone correct me if wrong, but aren't the overloads part of the "camper special" group (along with the rear sway bar)? There might be another option package they come with, but I'm not sure.
Bookshelf
May 18, 2011 04:20 PM
Mike Holmen
Oct 12, 2008 12:23 AM
megajoltman
Oct 20, 2007 08:40 PM
drewallen42
Jun 15, 2007 12:58 AM
plessm
Jun 13, 2007 11:12 AM
