Rear End Noise
Old Oct 6, 2007 | 11:10 AM
eot's Avatar
eot
Rear End Noise
I was wondering if any of you have had a rumble type of noise in your rear end when you are turning at low speeds almost to a stop. both in forward and reverse? Could it be the clutch pack in my rear end? How about any recomendations on fluid change. What type? Any info would be greatly appreciated. I have 13000 plus on her and the rear end fluid has never been changed. or any special additives to help?
Old Oct 6, 2007 | 02:11 PM
jrs_dodge_diesel's Avatar
Do you have a limited slip in the rear axle? If so, it's probably time for a fluid change.
If it's just an open differential, then noises are a bad thing here and you should open it up and take a look for pieces.
Old Oct 7, 2007 | 09:29 AM
Dazeys's Avatar
Add some friction modifier.
doorguy
Jun 8, 2007 06:19 AM
OFFDUTYEXPEDITOR
Feb 2, 2006 01:42 PM
DanHfmn
Jan 18, 2006 09:37 AM
DF5152
15
Feb 10, 2004 10:10 PM
wiz-1
Jun 11, 2003 08:51 PM
