rear end and front end diff
Im changing my diff fluids this weekend and was wondering how many quarts the front end holds and how much the rear end holds on my 99? Thanks.
They each hold about 1 bottle more than you'll buy at the time. Depending on your specific axle:
FRONT AXLE
Model 216-FBI 2.3 L (4.8 pts.)
Model 248-FBI 4.0L (8.5 pts.)
REAR AXLE
9-1/4 inch 2.1 L (4.5 pts.)
248-RBI(2WD) 3.0 L (6.3 pts.)
248-RBI(4WD) 3.4L (7.0 pts.)
267-RBI(2WD) 3.3 L (7.0 pts.)
267-RBI (4WD) 3.6L (7.5 pts.)
286-RBI (2WD) 3.2 L (6.8 pts.)
286-RBI (4WD) 4.8 L (10.1 pts.)
FRONT AXLE
REAR AXLE
I always purchase extra, simply for spillage, etc. The cold fill capacity is usually 1/2" to 3/4" below the fill opening. I have know many people that fill until it's running out, and then their pinion seals are leaking 6 months later. There needs to be some room for expansion.
Do you have limited slip? If so, do several tight figure of 8 patterns in a parking lot to get the new fluid worked into the clutch packs. If chatter exsists after that, then get a bottle of friction modifier, and add a little at a time until the chatter stops. Good luck!
afate45
Jun 7, 2014 12:08 AM
Bowser50
33
Jul 21, 2013 06:33 PM
banana
Dec 1, 2009 11:44 PM
SBRW
Jan 11, 2008 07:56 AM
doorguy
Jun 8, 2007 06:19 AM
