rear end
Old Aug 22, 2004 | 08:16 AM
nubby3's Avatar
rear end
Anyone runnining 308 gears in 3500 dually,auto trans.I saw 308 gear rear end for sale.How sluggish would it be for towing.Fuel milage.
Old Aug 22, 2004 | 10:26 AM
Copenhagenjunkie's Avatar
I would think it would be a dog.
Old Aug 22, 2004 | 05:03 PM
Smokee's Avatar
I had a 308 in a first gen. It did everything that I wanted it to...hauled car trailer, etc. Although there is was no overdrive stock, I had a Gear vendor that made about the same ratio as my 354 but without lock up.
I liked the 308
Old Aug 22, 2004 | 05:18 PM
amartinson's Avatar
Unless you had a gear vendors under/overdrive like Smokee, I think you would hate having 308 gears. Especially if you do ANY towing.
Old Aug 22, 2004 | 06:15 PM
MnTom's Avatar
3.08 would be an OK gear for an empty truck cruising the highways and byways. Towing, well I suspect that it would be a bugger to get the load moving from a dead stop especially when going up hill.
Tom
Old Aug 24, 2004 | 08:45 AM
CTD NUT's Avatar
You would likely being pulling it out of OD much more frequently than with a 3.54. Might be a better choice if you did not have an OD tranny but as Mntom mentioned, it would be a little sour out of the hole with a load.
Old Aug 24, 2004 | 02:54 PM
Stormin_Norman's Avatar
Can you say "arf arf". Unless you don't have an O.D., I would stay away from 3.08's. IMO 3.55's-3.73's -4.10's would be a better choice of gears.
Old Aug 24, 2004 | 04:21 PM
Mcmopar's Avatar
I don't see what overdrive has to do with it, both trucks would have the same first gear ratio in the tranny, so OD or no OD same tranny ratio!!
Old Aug 24, 2004 | 04:52 PM
CTD NUT's Avatar
I think what we mean is that if you did not have an OD tranny then you would have a nicer highway gear with the 3.08 than the the 3.54. But you are right, FIRST gear is the same for both autos so regardless of tranny the bottom end is going to stink, especially loaded.
However, the addition of an OD gear certainly makes your final drive ratio quite a bit higher than with the 3 speed, so even with 3.54 - 4.10 you can still have a decent highway gear. Running 4.10's with a 3 speed does not make for a very pleasant or efficient highway cruiser.
2500CTD
Oct 19, 2010 07:10 PM
RichN
0
Aug 6, 2010 06:52 PM
1999blackcloud
Jan 26, 2010 08:52 AM
doorguy
Jun 8, 2007 06:19 AM
royta
Jul 13, 2004 06:54 PM
