Rear Axle
Old Nov 20, 2002 | 10:29 PM
da-kine's Avatar
Rear Axle
new kid on da block. jus got da MAG-HYTEC diff cover for thee dana 80. went to several drive line shops. got different views on replacement lube. yet to remove da ole 1 to see if limited slip or not. any input? weight, synthetic, brand, etc...
Old Nov 21, 2002 | 04:58 PM
59Dsul's Avatar
Re:Rear Axle
I've always used standard gear oil from our farm. If you tow a lot, i've been told to use synthetic. I noticed no one had posted yet, maybe this will get it started for you.
Old Nov 21, 2002 | 07:22 PM
TPilaske's Avatar
Re:Rear Axle
I run Royal Purple 85W-140 in both Diffs. Others use Amsoil, Mobil 1 &amp; Valvoline. Lot's of choices... ;D<br><br>Tony
Old Nov 21, 2002 | 10:01 PM
Haulin_in_Dixie's Avatar
Re:Rear Axle
I am using Valvoline blend 85-140 and added the modifier. Now I do not have posi. Hope it comes back when I change it again.
Old Nov 23, 2002 | 04:36 PM
Alan_Reagan's Avatar
Re:Rear Axle
I used Valvoline synthetic and did not add friction modifier. Limited slip works great with no chatter.
nvr-enuf
Jan 30, 2014 06:56 PM
ian515
Jul 24, 2009 03:22 PM
mudwisr2
Feb 22, 2008 11:51 AM
MX429
Aug 20, 2006 06:41 PM
Paul Winey
Jun 22, 2004 08:09 AM
