Problem with 4wd Actuator
Old Nov 7, 2013 | 09:38 PM
Luckydog's Avatar
First off...thanks to everyone on this site for all the info I learned over the years...huge help.
Currently I am having a problem with my late model 2002, when I shift into 4wd the light on the dash does not come on all the time, sometimes does, sometimes does not. This has not been a problem yet, no snow here at the moment, but its on its way.
I looked at the front axle, I do not have the CAD system and I am relatively unfamiliar with the non-CAD setup. I believe my front end in turning all the time and only has power sent to it when shifted at the transfer case.
This being stated.....I assume when I shift into 4wd and the light does not come on 1) I have 4wd drive and there is a problem with the switch to the light or, 2) The lack of no light on the dash is indicating no 4wd.
I have been doing some research on this site with not much luck...anyone out there have any ideas!
Thanks again
Old Nov 9, 2013 | 10:55 AM
dubc2323's Avatar
if you shift into 4wd and the light isn't on try turning while going forward slowly you'll know if it's in 4wd. without the cad I would have to say you are probably in 4wd as soon as you shift it in.
Luckydog
Nov 8, 2013 09:33 PM
Tallguy67
ABDTR #5
Jun 18, 2011 12:11 AM
josterbauer
Feb 24, 2010 06:55 AM
bamadzl
Aug 13, 2006 12:07 PM
tjohnson
Mar 8, 2005 01:38 PM
