Possible rear gear problem?
I've changed the rear end fluid a couple times from dino to synthetic and back to dino with friction modifier and I'm still getting a kind of grinding feel. I don't hear it but I can feel it. Going slow and straight I can barely notice it but around slow turns or going in a circle I can really feel it. I'm also getting a "clunk" from time to time when I make a very slow turn and then let off the throttle quickly. Definitely coming from the rear end area. Any thoughts?
Mark
Mark
You might try adding a lot more friction modifier and see if it goes away. You might have an aggressive LSD.
That said, I had a similar-sounding grind in my driveline that went away when I had the Powr-Lok installed. So I think my rear was not setup correctly from the factory.
Mega07
Apr 26, 2008 09:37 PM
Fishbait
16
Jan 29, 2006 03:24 PM
robert chilton
Sep 10, 2004 06:37 PM
Rigg4x4
Nov 27, 2002 10:24 AM
