Pink coolant or Green coolant
From: 13 miles N.W. of Cleveland, TEXAS in the National Forest
You cannot mix green and or pink. It will gel up and cause real problems in the cooling system. After the flush, get as much of the left over out your system as possible. I use an inline flushing T installed on the heater hose to reverse flush the radiator back through the filler neck with a regular water hose. Crank it and warm the engine till the t-stat opens a time or two with plain old water still running to get much of the flush outa the system as you can with the radiator petcock open. Shut her down drain out all the excess possible. Close petcock, get 2 gallons of quality "green" glycol antifreeze, 2 gallons of distilled water and a cooling system additive to go back with when you finish the flush. Piece a cake.
Fleetguard coolant, distilled water (or get premix) and LOTS of Redline WaterWetter. I use 3-4 bottles of WW in a system the size of the CTD.
Or, if you can afford it, go with Evans NPG+
jlh
jlh
DL1221
Aug 24, 2006 12:09 AM
