PECM, -------, and PDONE
Silly title I know, but these are the codes I've extracted from my "new" HO 2500 with 173000 miles.
I'm pretty sure I get what the PDONE code is, but what is PECM and -------?
Thanks!
Thanks!
Reading the codes with the on, off, on, off, on key trick, it should go thru 2 cycles. 1st is the PCM and the 2nd is the ECM. After the 1st Pdone, it takes a few seconds for the next code reader to start. No numbers coming up is a good thing.
Another key trick. Hold the odometer reset in and turn the key to on. It will say check in the odometer window, then the odometer will do a snake dance, and check all the leds. The warning light in in the instriment panel will come on and the gauges will go up, 1/4 1/2 and peg them. Cool to watch.
sleeperman
Mar 8, 2011 02:56 PM
notpowerSTROKIN
42
Nov 10, 2007 09:02 AM
bigthumper
Aug 8, 2004 08:21 AM
Zino
Dec 16, 2003 05:19 PM
