P1693...DTC In ECM...Anyway to clear?
Old May 28, 2008 | 01:20 PM
Dinner's Avatar
Hello,
I have my XZT+ with Quadzilla currently being looked at/tested in one of their trucks because it was giving me problems. The fellow from Quad asked me if there are any codes on my truck. Went out this morning, put a scanner on it and found 2 codes. The first one was a code in the tranny. My speed sensor is shot so my speedo and odometer aren't working currently. And the other was the P1693 code. The scanner says that the ECM detects a code in the PCM. So is there anyway to clear the code in the PCM? And would that code perhaps mess up my XZT+ in any way?
Thanks!
Old May 28, 2008 | 02:19 PM
John Faughn's Avatar
Not all scanners will retrieve all codes , and not all scanners will clear all codes , so what kind of scanner is it , and who is using it ?
That is a companion code , and should be cleared after repair , did you fix the 1st problem , the non working odometer ?
You can clear a code , but it will come back of you do not fix what the code is for .
Old May 29, 2008 | 12:44 AM
Dinner's Avatar
The scanner being used is a Snap On Solus Scanner and I was the one running it.
I have not fixed my tranny speed sensor yet, just haven't had time to get the part or replace it yet...so maybe that is just the 1693 code showing the in ECM, telling me that the code for the speed sensor is at fault in the PCM.
I was just curious as to if that companion code could have anything to do with Fuel relation...XZT+. But I'm starting to think that it doesn't.
Old May 29, 2008 | 09:27 AM
That means that you are still going to have the other , speed sensor code , with the lack of data from that , and the companion code , the computer should not be expected make the correct decisions , the old computer saying , bad info in , bad info out .
With a good pro scanner , your much better off than the $50 -100 limited tools .
Old May 31, 2008 | 04:22 PM
phox_mulder's Avatar
Truck has two main computers, the PCM (Dodge computer) and the ECM (Cummins computer).
P1693 is the code thrown in the ECM when there is another code in the PCM.
It also goes the other way, and will be thrown in the PCM when the ECM has a code the PCM doesn't understand.
You won't be able to clear the P1693 until the other code in the PCM is gone.
Once you fix the speed sensor, the P1693 should go away on it's own.
phox
Old May 27, 2020 | 11:48 PM
Ezekiel Worst's Avatar
phox
I’m having the same issue however when I select the PCM to dig into the reason for the code, nothing shows other than the P1693 code. I’ve tried clearing the code out of the PCM and ECM but no luck. Any ideas? Key cycles don’t clear the code either. I’m using autel’s scan tool and system to check codes.
loakes01
0
Feb 4, 2013 02:11 PM
dccjml
Jan 2, 2010 10:37 AM
nasty01cummims
Mar 22, 2009 12:46 PM
blackdodge24
Nov 25, 2006 01:31 PM
1882
Aug 21, 2006 02:27 PM
