Oil leaking on drivers side of block
Old Feb 3, 2007 | 07:16 PM
sdsaw's Avatar
Replaced vac pump seal but didn't stop my oil leak.
Seems to be leaking somewhere around the injector pump and above the motor mount.
Already checked the valve cover gasket and where the PS/vac pump bolts to timing case.No leaks here.
I want to try to tighten the bolts holding the tappet cover down.I noticed that there is a flexible cover on top of the steel cover.My question is: For anyone that has done this,what parts do I need to remove to gain access to be able to tighten the bolts holding down the steel cover.
Thanks, Scott
Old Feb 5, 2007 | 05:46 AM
bluedodge3500's Avatar
mine did that after an injection pump replace by the dealer took it back in and they charge me 900.00 to replace the breather tube assy. to put it to the back they said there is a plate behind the injection pump that was leaking and it needed the update I should have just pulled the injection pump myself to look but I thought they did it but they said they didnt (yea right) I pulled everything apart on that side to find it myself but couldnt see it
joem
Apr 10, 2012 12:14 AM
plcnut
Jan 13, 2010 10:23 AM
loosendend
Jan 31, 2008 07:55 AM
b.lee
Jul 15, 2007 01:19 PM
rich
May 16, 2005 02:48 PM
