oil blow-by
Old Sep 11, 2006 | 06:40 AM
deezl's Avatar
oil blow-by
just this week i noticed that there is a noticable amout of oil comming out of the breather? i just changed the oil today, all ways us rotella 15-40
any ideas in what it would be would be great..
maby piston rings, head gasket
Old Sep 11, 2006 | 08:57 AM
nitrousn's Avatar
Did you empty and clean the blow by bottle?
Old Sep 11, 2006 | 10:41 AM
Bart Timothy's Avatar
Don't make the mistake of comparing the amount of blowby of these engines with a gasser. They have a suprisingly, much greater volume of blowby, which is normal for them.
The pill bottle was put on the end of the breather tube to catch oil from blowby. The bottle should be cleaned at every oil change or relocated to a place where the fan can't catch the oil mist from it. Oil from the bottle, caught by the fan, and deposited on the radiator, is the biggest single cause of 24v over heating.
For serious off the roading, the breather should be moved off the front of the engine to the rear of the valve cover. Loss of over a gallon of engine oil out the breather isn't uncommon when driving down a steep enough incline.
Old Sep 11, 2006 | 03:17 PM
H2SRDMB's Avatar
been there, my truck is now called the rotella valqueeg ( valdeze referecne+nickname) lost over a gallon last oct backing up a hill to park! finally moved the bottle and 3 oil changes later a slight amount in the bottle.
i seggest everyone move the bottle. easier to clean and minimises loss of oil too!
Old Sep 11, 2006 | 05:52 PM
deezl's Avatar
I cleaned the bottle the day of the oil change.... 2 days later the is a smell of oil and the bottom of the check can is covered...
Now i have lived in the same house for the past three years. drive up and down the same hills and it was only this past week that there seems to be oil gushing out of this breather.. The breather is in the OEM location for now.
Old Sep 12, 2006 | 11:05 AM
coalburner400's Avatar
Could be the vacuum pump seal going out.
Old Sep 12, 2006 | 12:02 PM
ATM2754's Avatar
I don't have my truck yet, but when I do get it, Is the rear of the valve cover the best place to move the bottle??? and how do recommend securing it???
Diesel-Dan
Nov 6, 2016 12:31 AM
Got Smoke?
22
Mar 7, 2004 12:37 AM
tls2
Aug 2, 2003 06:52 PM
tamalerocket
Jun 2, 2003 12:22 PM
