NV4500 4-speed
Old Sep 21, 2007 | 11:25 AM
ram99's Avatar
NV4500 4-speed
I lost 5th gear on the way home the other day. No noise no grinding and no 5th gear. Wondering if this can be fixed without pulling the transmission. Probably wishful thinking I know.
Old Sep 21, 2007 | 01:32 PM
Chass's Avatar
Yes it can.
The nut fell off the end of the shaft where 5th gear is held on.
You pull the transfer case, pull the tail off the transmission, put 5th gear back in place, put the updated nut from the dealership with the little locking allen heads back onto the shaft and reassmble.
I had mine done by a friends shop. He needed some work and I didn't have time. The job was rated at a 4 hour job. With parts and $60 worth of tranny fluid (can't just use 90 wt) it cost me a total of $340 which included new bushing and seal for my T-case output.
Its an easy job if you want to do it yourself and it should be pretty cheap to have a shop do it too. Its not problem to drive the truck to the shop.
Chass
ct
Old Sep 21, 2007 | 09:29 PM
ram99's Avatar
thanks, I'll give it a try.
tennessee
Feb 20, 2011 02:12 AM
SilverSootXpres
Mar 23, 2010 07:18 PM
Fozz
Aug 17, 2006 09:33 PM
TFPace
Nov 17, 2004 09:04 PM
