NV 5600 conversion?
Old Aug 4, 2008 | 09:22 PM
rams2500's Avatar
NV 5600 conversion?
I have a question that may have been discussed already but I was wondering if the nv5600 can be replaced by what is running in the newer trucks. I know the 5600 parts are hard to come by and they have had there share of problems. I looked at a 2001 3500 dodge 6sp that didn't have 4th gear. Is it easier to swap to a newer trans (if possible) or repair the stocker. Thanks for any info.
Old Aug 4, 2008 | 09:47 PM
dozer12216's Avatar
Would try and figure needed parts expense for 5600 as opposed to cost of replacement tranny. Might be much cheaper to repair.
Old Aug 4, 2008 | 09:59 PM
UnrulyNFS's Avatar
The G56's are expensive and not as strong. They shift sweet if your not going to be playing hard. I just put a rebuilt one in that cost as much as rebuilding a NV5600. Stoopid Germans.
Ebay actually is a good place to get some pricing guestimates.
Old Oct 18, 2008 | 08:37 PM
chansey's Avatar
Fuller 6 Speed Swap
I'm just finally wrapping up the installation of a Fuller FSO6406A transmission to replace the dreaded NV5600 issues. Three (3) failures and only 112,000 miles.
I have pictures and parts required to do the change-over on my web site http://<span style="color:Red">http:...600.htm</span>. My total cost so far is under $2,000 because I've provided my own labor. Basically it is a remove and replace operation with the exception of the fabrication of the support bracket for the transmission, hydraulic slave cylinder and drive shaft modification.
Fuller parts are cheap and plentiful and you can rebuild it yourself if you have to and you have a 14" clutch too.
Old Oct 18, 2008 | 08:45 PM
98whitelightnin's Avatar
Does anybody know if the dodge and chevy 5600's are interchangeable. The only difference that I know of is that the 93-94 chevy's 1st gear is lower.
Old Oct 18, 2008 | 10:06 PM
thumper549's Avatar
5600 s are junk, do not wast your $$ or time
Old Oct 19, 2008 | 08:15 AM
Valv's Avatar
5600 are not junk, people misconception is scary sometimes.
They are also very available. I have a large plant nearby with 6 on the shelves, www.zbag.com, $ 2900 for a complete rebuilt and warrantied.
The GM version is same as Dodge since New Venture was a joint venture between the 2.
This discussion will go on forever since there are 2 biased parts. It's like discussing 12V vs 24V, Ford vs Dodge vs Chevy, etc.
The newer G56 is not as strong as the NV5600
Old Oct 19, 2008 | 09:56 AM
johnh's Avatar
link doesn't work
Old Oct 19, 2008 | 10:38 AM
Valv's Avatar
Fixed mine. Thank you.
Old Oct 19, 2008 | 03:53 PM
thumper549's Avatar
Valv ! I getting the idea you are a vendor / fix it shop ! Why not tell the truth !!
I think you would rather sell parts maybe ???
Sorry, calls em as I sees em
Old Oct 19, 2008 | 03:59 PM
rich's Avatar
had all 3 the 5600 is no worse or better then the g56 broke em all sad thing is the g56 started going bad at around 6k on the truck. the others at least had some miles on them
Old Oct 19, 2008 | 04:06 PM
thumper549's Avatar
I will agree with that.........so so true . Now I have found a cure hope you do too !!!!! LOL
Old Oct 19, 2008 | 04:36 PM
Valv's Avatar
Thumper, you are wrong again. I am just a hauler and I use my truck a lot, put a lot of miles on them. I am mentioning the Zbag name since I was impressed from the setup and business, I juts bought a transmission from them and an axle for a farm truck.
I feel $ 2900 for a rebuilt NV5600 is quite a good deal, especially since they do the work, and I am passing the knowledge around. If you don't like it that's your business, but don't accuse others, as you can see again the facts are against you..
As I said the discussion about NV5600s will go on forever, you have your opinion, I have mine, but please don't step on my toes.
Old Oct 19, 2008 | 05:41 PM
thumper549's Avatar
I see you talking...I see your link or advertisement...Me thinks there is link there.
"Everyone else " knows the NV stuff and the G stuff are crap... I do not know why your guys would not know..being they have a warehouse full of stuff to sell. LOL The fact that those transmissions have run out of parts in the past speaks for it self! It does in fact need a warehouse some where to support them.
Most "real" Trk trannies will go over the million mile mark B4 TBO.
That's what I know...not sure as to what you know as your EXP as only a driver may have varied.
Hay, not mad Ya , Just calls em as I sees em.
If you were to post a survey here about where those tranns rate you will learn what I already know.
thanx
Old Oct 19, 2008 | 06:36 PM
Valv's Avatar
I think everybody can see you talk, but not the walk. If there were lack of parts, how come they have them rebuilt and ready to install ?
Where do you get your info ? You've been reading too much from business thar are not in business anymore, I wonder why....
How many miles on your Mercedes ? We'll see in few years what happens to it.
