Nubie Question
Nubie Question
1. This is my first post and I am looking for advice on how to make my CTD run a little better. Can you tell me what to do???
<br><br>2. I have already installed a Blue woolen seat cover and removed the airfilter..as well as installing a Tornado in the intake.<br><br>3. What is a silencer ring???<br><br>Thx in advance
Re:Nubie Question
[quote author=KwikKurt link=board=4;threadid=9941;start=0#94910 date=1043243575]<br>1. This is my first post and I am looking for advice on how to make my CTD run a little better. Can you tell me what to do???
<br>[/quote]<br><br>If Iam reading this wright...put your air filter back in and dump the tornado...keep the woolen seat cover<br><br>The silencer ring is only a addon that dodge requested to keep turbo wine down<br><br>There are many things to do for more horse power....hows your credit line ??
Re:Nubie Question
First of all, what year truck do you have? Fill out your personal profile so we can help you.<br>I agree with removing the tornado. JUNK.<br>If you have a 24 valve you may start with an Edge Ez. Before tranny or clutch upgrades. Cut the exhaust and straight pipe, or stack it.<br>From there, you can do numerouse things for performance.
Re:Nubie Question
If this is the same KwikKurt as on the DTR I'd suggest: :
<br><br>A stock truck to compare with ;D<br><br>An ISX or better a N14 and bomb on from there.
<br><br>And keep the blue wool seat cover. A penguin sticker on the rear window could give you some serious torque
<br><br>AlpineRAM
<br><br>AlpineRAM
Re:Nubie Question
Hey Kurt,<br><br>I'd recommend an aftermarket turbo from Piers.. ;D
<br><br>Yes, this is Kurt Yardley of the B1 bomber fame... His email is<br>KDRVTRUCKPERFORMANCEINC@MSN.COM<br><br>Charl es
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:Nubie Question
<br><br>2. I have already installed a Blue woolen seat cover and removed the airfilter..as well as installing a Tornado in the intake.<br><br>3. What is a silencer ring???<br>[/quote]<br><br>1) Quit eating hot chilli-peppers.<br><br>Well, I dunno if that'll help your truck run any better or not, but the smell is killing us.<br><br>2) Jeez, I told you. Seat covers on the intake, tornado on the seat. Gives you that jet-ride feeling.<br><br>3) Follow the advice in 1) and you won't need a silencer ring.<br><br>Rod
Re:Nubie Question
Blue sweaters add 20 HP
Kwikkity glad to see you aboard.
How is the [censored] and the new [censored] coming along?
The teflon lined [censored] is in Canada. ;D
Rod needs help on his 03'...send him that other turbo asap.
Re:Nubie Question
[quote author=Push Rod link=board=4;threadid=9941;start=0#95081 date=1043263834]<br>[quote author=KwikKurt link=board=4;threadid=9941;start=0#94910 date=1043243575]<br>1. This is my first post and I am looking for advice on how to make my CTD run a little better. Can you tell me what to do???
<br><br>2. I have already installed a Blue woolen seat cover and removed the airfilter..as well as installing a Tornado in the intake.<br><br>3. What is a silencer ring???<br>[/quote]<br><br>1) Quit eating hot chilli-peppers.<br><br>Well, I dunno if that'll help your truck run any better or not, but the smell is killing us.<br><br>2) Jeez, I told you. Seat covers on the intake, tornado on the seat. Gives you that jet-ride feeling.<br><br>3) Follow the advice in 1) and you won't need a silencer ring.<br><br>Rod<br>[/quote]<br><br>You guys are to sharp... You found me out!! Sure enough this is KwikKobraKurt.....<br><br> By the way my Email will be changing soon to my Older Buisness Name of MILD TO WILD Performance Diesel inc. I recently bought out a Investor I had taken on 1.2 years ago when I set up a shop here in SW New Mexico.<br><br>Thanks for the Advice:<br><br>Ok I switched to straight Pickled garlic......
<br><br>The Tornado on the seat idea!!! Why didn't I think of that!!!!<br><br>
Re:Nubie Question
[quote author=Idaho CTD link=board=4;threadid=9941;start=0#96346 date=1043476565]<br>Sure enough this is KwikKobraKurt.....<br><br>I thought it was "Sparky" of Southbend clutch wrecking May Madness fame.<br>[/quote]<br><br>Potatoe CTD, ;D I just replaced that clutch a couple of weeks ago. I am testing a "AWSOME" 15 stage Propane system I helped develop and need the new Hybrid SouthBend Con FE Clutch setup to get it to the ground.<br><br><br>Floored IT, I hope to start the R&D soon. I will probably wait as we have a couple of versions of the B-1 coming out that will address the surging issues a few trucks have with the Huge compressor we run in the B-1. We hope to have lower EGT's, Faster spooling and OFCOURSE More HP..... ;D ;D <br><br>One new Turbo (Still from the B-1 Line)that we are building will allow it to be bolted right in with no exhaust modification. That way it will accept the Turbo mount exhaust brakes!<br><br>For those of you that have been wondering the B-1's are built using mostly Switzer Turbo parts. <br><br>Kurt Yardley<br>Mild To Wild Diesel Performance inc.<br>5405-534-0434
