noobie questions
noobie questions
noobie here..... <br><br>just baught this Dodge Truck as it is it has a VA box on it i do not plan on modifying this truck in any way (i said the same thing about my stock Jeep 4 years ago (now it is sittin on 42" tires with a custom designed suspendion by me) <br>anyway the truck has 74,000 miles on it with a recently replaced tranny from the *********** under warranty. i am planning on adding the fuel pressure gauge because of the horror stories ive read about on this BB. i am using this truck as a daily driver and to haul my Jeep arround (8-9K trailer) to wheel. <br><br>a) should i leave the VA box on it i dont want to f-up the tranny... i can hardly take off from a stoplight without spinning the rear pass side tire (which is balding more and more everyday)<br><br>b) it appears that the boost incerase out of the VA box has the wrong plug on it and is not hooked up what gives ?<br><br>c) can i get a 3 gauge pod for the pillar if i have an exhisting speaker there<br><br>d) i am getting right at 500 miles per tank (27 gal at fill up) is this bad - avg - good - great ??
Re:noobie questions
[quote author=redruM Hauler link=board=4;threadid=12475;start=0#117957 date=1048089031]
noobie here.....
[/quote]
A) The VA should be fine for your tranny.
If you add any injectors, you may be in trouble...
B)Sounds like it might possibly be a VA for a different year truck? ???
C) Yep, lots of vendors sell them for trucks with tweeters. I got mine from Piers Diesel.
D) Sounds good to me, especially for an Auto! ;D That's 18.5mpg!
noobie here.....
[/quote]
If you add any injectors, you may be in trouble...B)Sounds like it might possibly be a VA for a different year truck? ???
ddog87
Apr 17, 2007 10:08 AM
