New Tires
Old Sep 1, 2006 | 12:21 PM
cjthor's Avatar
New Tires
I purchased new tires yesterday on a whim. The couldn't stand the old.
The new tires are Dueler Revo AT's, 235/85/R16 load range E. So far, so good. I have only put about 70 miles on them.
They are 32.1 inches tall, Bridgestone says they turn at 649 RPMs.
The old tires were ProComp All Terians, 285/75/R16. Load range D, never will buy load D tires for a Cummins agian. These things were almost shot before I had 39,000 miles on them.
They are 32.9 inches tall. This is what the truck is currently set to run with. I don't know how many RPMs they turn at. The same size Bridgestone tire turns at 631 RPMs.
Should I expect my spedometer to be about 2-3 mph off?
Thanks,
Cjthor
Old Sep 1, 2006 | 12:41 PM
dodgezilla04's Avatar
yes, there is a 2 1/2% difference is size between your old and new. 3 mph off is expected.
Old Sep 1, 2006 | 05:19 PM
nitrousn's Avatar
Thats the reason the factory installs the E load range tire. I would never install a D rated tire on any of my trucks.
Old Sep 1, 2006 | 05:51 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Plug in your tire sizes to see how far off your readings will be.
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Looks like @ 60 mph you'll be 2.08 mph off.
Old Sep 1, 2006 | 06:08 PM
Danderson's Avatar
E range tires
I finally installed a set of e-range tires onmine. Went from 285-75-16 BFG's to a set of M-55 Toyos,same size. What a difference. Besides actually being a round tire,the M-55's handle the camper weight super. Really pleased. As posted a slight singing between 40-50 mph but nothing that these noisy suckers can't drown out.
Old Sep 1, 2006 | 08:47 PM
nitrousn's Avatar
You are doing it right by getting the E rated tires. The D are 8 ply and the E are 10 ply sidewall. A D rated tire may seem smoother but the heavy weight will push that tire and cause premature wear. If you are going to pull a trailer, or camper a E rated tire it a must. Plus there is a liability factor. All tire shops i know of in my area wont install a D rated tire on a truck that is Built with E rated tires just because of the liability. The way our courts and lawyers are any one who installs a D rated tire is leaving their selves wide open for a lawsuit in the event of an accident no mater if the tire is directly at fault or not.
chrisminx
14
Jul 7, 2010 06:48 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Captain
Sep 9, 2005 12:16 AM
