Need replacement for Amsoil SDF 26 oil filter
Old Jul 4, 2006 | 07:05 AM
Rdway60's Avatar
Question Need replacement for Amsoil SDF 26 oil filter
Hey All,
I have the Amsoil BMK-15 Ea bypass filter system in my newly acquired 01 24 valve Quadcab. I have purchased the EaBp 100 low micron filter and want a replacement for the SDF 26 amsoil full flow filter. Fleetgaurd, Donaldson, etc. numbers would be very acceptable if anyone can cross some numbers for me.
Thanks in advance....Rdway60
Old Jul 4, 2006 | 09:18 AM
rebal's Avatar
Is it the amsoil dual remote set up?(2filter side by side). If i remember right a Fram HP1 will fit but I personaly would cross referance it to a Wix or mobil1 filter.Im no fan of Fram filters .hope this helps
R
Old Jul 4, 2006 | 09:45 AM
Rdway60's Avatar
Rebal,
Yes it's the dual remote system. I am pretty much set on a Donaldson, Wix, Fleetguard, or their equivelent..ie heavy equipment type suppliers. I use fram on my 2 gassers with no problems over the years but have read not very good posts with cummins usage. I stopped at a few parts stores and the local International heavy truck dealer and was told he couldn't cross with my DSF number I'm sure somebody has the info I'm after and hopefully will find what I need to "Gidderdone"
Thanks Rebal
Old Jul 4, 2006 | 01:48 PM
SuperDiesel's Avatar
I have been a big fan of Amsoil and Donaldson. Their ELF endurance oil filter has nano fiber technology which is very, very effective. Combine that quality of a full flow filter with the EaBP bypass filter that you already have, and your truck will run forever. The ELf endurance oil filter that is used on the Cummins is Elf 7349. Imho, superior to wix, which is very good also.
Old Jul 4, 2006 | 04:55 PM
rebal's Avatar
Hey FYI the amsoil dual remote will take any 2qt older Chyrsler/ ford spin on it has the same threads. might help you .
also a wix 51515R will fit and filter very well
Rdway60
May 17, 2012 02:18 PM
richie waddell
May 11, 2009 04:07 PM
jmccart
Dec 11, 2008 02:49 PM
czkid
Oct 18, 2007 07:38 PM
MoreSmoke
Feb 25, 2004 11:06 AM
